TC Mueller
- 169
- 0
- Jun 23, 2006
Bartlett,
Illinois
My car was sitting for about 4 months without a start and had a bad battery, so I changed that 2 days ago. But my problem now is, when its cold the car refuses to turn over. it cranks and then every once in a while it'll sound like its going to turn over for a second, but doesnt and just goes back to cranking. I know have the correct things to make the car run because it started in a warm garage 2 days ago when i pulled it out after the battery. I also checked the coolent temp sensor and connections were fine. If it helps at all, when the car did start, it would idle extremely bad and most of the time die. Untill it warmed up then everything was fine. The idle was extrmely low, like below 500 low and the entire car was sort of vibrating, more thatn it already does any help at all would be wonderful. Thanks guys.
