intimidator2000
- 166
- 1
- Sep 16, 2004
O,
Florida
I really need to change my antifreeze, but I don't how many bottles of antifreeze will I need to buy to fill it up.
Green
Ha Ha. I mean the specs. Like gm takes that special gm red crap with the spec that I cant remember off hand.
It's about a 2-gallon system, so one bottle of pre-mixed Preston and a gallon jug of distilled water will do you. Put in the Prestone first, and finish with the water.
Is it really? I always thought it was 1 gallon?
Just fill er' up until she tops off. Any excess with be dumped through the drainage tube. Not only that, but you should add some Water Wetter in there also. Any leftover coolant should be stored away for future use. Simple as that.
I though water wetter was supposed to be mixed with water only, no coolant is needed.
Well, it could probably be used either way, but on the bottle I'm pretty sure it says for best results mix with water only.
