dsmfreak555
- 54
- 0
- Dec 7, 2006
kailua,
Hawaii
What do think about this budget setup?this is to add on to whats already in my profile
modified stock sidemount/supra sidemount (if i can find one)
alchy/water injection(absolute must since i cant afford a fmic)
2g throttle body elbow
ported 2g mani
ported turbo and ported 2g o2 housing
as far a fuel if you look in my profile i have pretty much everthing except lines. and the chipped ecu has extending timing and fuel maps and a 11:1 afr map. i was going to try and run as much as i can with the current turbo(i might actually have a 16g in there )
I just recently jump in a friends car with a 16g at 20 psi and a decent tune and it didn't feel that much faster than mine and i have a bad clutch!
andy told me to pull of my intake and look to see if i have a twin blade compressor(16g variant). let me know what you guys think. My friend is going to let me use his logger so ill just turn it up the most i can boost wise before getting knock.
As a side note is there anyway to shim the wastegate actuator on the 14b to hold higher boost? (i think maybe i should've started another thread about that) any opinions would be helpfull...like things i am missing!
ported 2g mani
