andymoraitis
- 3,241
- 154
- Jan 25, 2004
Utica,
Michigan
That sounds pretty normal for a 264/272 combination but the best way is to physically check the cam gears with cylinder 1 at TDC. Yan can pull all four plugs to make rotating the crank pulley easier when you do this. Also, how many inches of vacuum do you pull at idle?
I personally think you just really need to boost leak test it and Seafoam it to see what's happening in the intake and exhaust tract.
