iamtall77
20+ Year Contributor
- 185
- 1
- Oct 9, 2002
Las Vegas,
Nevada
I pulled my lifters to clean them. Stock 2G turbo with 86k on it. Noticed that there was a large variation in how easily they turned and compressed. Didn't think much of it, cleaned them and put em back. Car wouldn't start. Tried everything I could think of, then pulled out the compression gauge. No compression on 3 or 4, but was fine on 1 and 2. I put everything back where I found it. Pulled the valve cover and no obvious signs of bent valves. Pulled everything back out and noted my findings.
The #3 intake tranny side compresses too far. The other is tough to spin.
#2 intake tranny side also compresses alot.
#1 intake timing side does not compress and is very difficult to spin.
#4 exhaust timing side does not compress.
#2 exhaust timing side does not compress and is difficult to spin.
Both #1 exhaust side do not compress and are difficult to spin.
I also noticed there are at least 3 different sizes with a quick measurement on height. Are these all junk?
I also did a quick look at a set of lifters I have laying around. They seem to compress and spin consistently with the few I checked. I'll probably swap them out, but thought I would put my findings here. I'll also check to see if there are any variations in height.
