nwgtr
- 0
- Oct 9, 2006
toronto,
Ontario_Canada
hi, please claify the different fluid for the transfer case, manual transmission and the rear differential please.
i have been using what the user manual saids. sae 75w-85w for the tranny and the transfer case.
and the rear diff i used some gear oil rated at sae90.
but i heard some people used something called a syncoshift for both tranny and rear diff?
so can i used the same fluid for all 3?
Another thing i would like to know is, lucus makes this transmission leak liquid which helps stops the seals from leaking in the transmission. can I use that on the rear differential or transfer case.....? I know for a fact that my rear diff seal is leaking but if i can use that on all 3 i might just put some in just incase so i can get through the winter and start fixing it in summer.
if not which kind of fluid can i used to stop the seal from leaking?
