htaracing
- 0
- Jul 12, 2006
Blairsville,
Pennsylvania
I just had my 1998 420a rebuilt for my new turbo kit. The crank, main bearings, rod bearings, pistons, and rods are all already in the block. The only parts i need to put together are gaskets, water pump, oil pump, oil pan, and what not. My question is how do i go about this, where do i start? Where do i put the engine oil assembly lube, RTV permatex, and what not. And whatever things i need to know that would be helpful to putting the motor back together. Thank you
