Mitsutalon
- 0
- Nov 6, 2003
G. Heights,
Illinois
finally intalled mine today.. the swap went very well and easy.. since this would be the 5th tme im changing my suspension and hopefully it will be the last. .... right after i got the whole swap over, i took the car for a tes drive and wow what a difference on the handling department... the car feel more responsive and tight... the ride wasnt to bad except for the deep bumps and such then you really feel those high spring rate work...... over all i lke the suspension so far... the only thign that i havent done is is adj. the dampening... im kind of clueless on how i install this know adjuster things and how to set them..... if martin can hit me up about this and maybe can give me some technical help that wou be great...
over all i think this product is one of the best buy ive had in a while, for the money i spent on this thing and the performance difference i get from it is bar none.... especially the great customer service.... thanks martin
Steve R..........
Steve R..........
