Spoolinsleeper
- 0
- Mar 16, 2005
Brunswick,
Ohio
I have a question and a slight problem: I recently switched the exhaust housing on my turbo because the old one had cracks in it (i have a 14b). The old one was ported and the new one is ported as well( though not as much as the old one). At the same time I switched exhaust manifold because the old one was severely cracked. its still a stock mani. ,but this one is ported. Now when I drive my car, the A/F gauge doesn't read the same. it doesn't sweep back and forth as much, it usually sits at lean and when it does sweep (though somewhat rare) it only sweeps from lean to stoich. Also,under full throttle, it reads at stoich(a little towards rich). This is a problem because it used to always sweep from lean to rich at all times and under WOT it used to read at rich. So now the question: did swapping those parts somehow change my A/F ratio? I don't see how it would, and if it didnt, what would be causing the different reading? please let me know if u have any ideas, questions, or answers. thanks.
