DSMTurbo2
20+ Year Contributor
- 34
- 0
- Dec 17, 2002
Traverse CIty,
Michigan
Ok first off the mods:
92 laser awd 6/4
b16g
evo exhaust mani
evo o2 housing
full 3"turbo back
rewired 255lph
stock FPR (have an SX ready needs fittings)
boost controller set to 15psi
3" intake pipe
dejon turbo outlet pipe
bpr7es plugs
unhacked mas (all restricters removed)
k and N (open can)
mmcd pocket logger
i think thats about it..
so first off i understand i should have an after market FPR on there.. im working on it!! the car has been running amazing on and off... i think the knock sensor might be bad (its the original has 126k on it) i have another one i can throw in..
But my problem is>>> I have been logging and turning tthe boost up (the boost controller is a dual stage) i would flip it to 19lbs and long story short it would propel six foot flames out the exhaust... so i stopped with that... ive had it sitting at 15lbs ever since..
ive been logging and feeling allot of fantom knock (43 counts) while crusing 55mph on a strait flat road. my logs have been pretty good.. nothing drastic or scary... usually when i do a good pull i get 0-3 counts i have seen 7 a few times.
so the big issue was last night.. i did a good third gear pull.... was watching my egts started around 4500 when i first hit 15lbs then held at about 5000 then all the sudden spiked up to im guessing around 7000-7500 and the car just started pulsing (i wonder why)... i happened to be logging at the time and when i reviewed the log i noticed somthing odd that i believe was at the same time all this occured here was what i got:
fuel trims:
L: 139.8
M: 96.8
H:92.1
just before the weirdness:
RPM: 5687
02: .82
INJ PW: 19.45
knck: 22
TPS: 99.6
first start of the weirdness:
RPM 5875
o2 .76
INJ PW: 11.51
Knock: 43
TPS: 99.6
worst spot in o2's
rpm: 5812 (dropped even thow i was trying to accelerate.. the pulsing??)
o2: .00 !!!!!!!! (not good!!) thats right 0.00
INJ PW: 13.31
knck: 42
TPS: 99.6
Now before this log i thought maybe i was getting some unburnt fuel from maybe some bad plugs... and it was just causing a little hesitation (since i didnt have any knock during a pull) but now im really lost... any help in pin pointing this.... im headed out to check and prolly change my plugs right now... but with those o2's im really confused... please help me.. sorry for the long story.
thanks, Erik.
92 laser awd 6/4
b16g
evo exhaust mani
evo o2 housing
full 3"turbo back
rewired 255lph
3" intake pipe
bpr7es plugs
k and N (open can)
mmcd pocket logger
fuel trims:
L: 139.8
M: 96.8
H:92.1
RPM: 5687
02: .82
INJ PW: 19.45
knck: 22
TPS: 99.6
RPM 5875
o2 .76
INJ PW: 11.51
Knock: 43
TPS: 99.6
worst spot in o2's
INJ PW: 13.31
knck: 42
TPS: 99.6
thanks, Erik.
