frigidgsx
- 0
- Oct 18, 2003
Long Beach/Gloucester,
California
Morphius said:1. Serious contender? 230 hp is pretty darn good out of the box. Exceed 1G and 2G stock. It's already putting down some serious numbers. When stage 3 hits, the EVO better run and hide.
Feel the wrath!!!
2. hmmm, interesting. I'll see what I can find out regarding bolt patterns. Just might.
3. No fading. Just evolution.
-DaimlerChrysler Engineer
If your going to try and compare engines, atleast do it with some sort of level playing field.
the srt-4 does have more hp stock than a 1g-2g, but it also has a bigger turbo stock(among other parts)...put the same exact set up on a 2g(as it runs closer to compression if that 8:8:1 was correct) and then compare numbers...
and whats this stage 3 crap? Is it going to be a model, or just performance parts you can add, for I'm sure a greatly increased price, through the dealership?
Either way its just like following Buschurs(or other vendors) "staged" upgrades...
either way this argument is not going to be settled until someone does install the same exact set-up throughout many engines and finds the results....
