AMS stampy
- 279
- 4
- Oct 21, 2003
eclipsegsx9797 said:go with the gt35r for sure, with the to4s cover and a .82 a/r. id also go with ams custom gt35r that they have made. its just alittle bit diffrent but its worth the extra 100 dollars. this turbo is alsome ive seen cars with 2.3 setups trap all day in the 130's.
eric the white 1g from ams put down over 550whp at only 26psi if im not mistaking with there gt35r. his car is daily driven also and traps all day in the 130's. id give ams, agp, sbr, br, or some other known shop a call and ask for more details.
as far as any other turbo out that that makes great power is the fp3065 this turbo is nuts for a bolt on. its pretty much a bolt on gt30r but seems to work alot better, it seems to put down better time's then even the gt35r. its a huge decision if your looking at these two turbos and im sure you would be happy with either one.
Thanks Jim. I made 580 whp on 26psi and the car traps 135.7 currently. Havent tried with the the new T04 housing and tubular manifold but I am sure she will hit the 140 range no problem
Eric
