focusedrage
20+ Year Contributor
- 1,053
- 0
- Aug 3, 2002
Laytonsville,
Maryland
This was my first "good" log with dsmlink, I dont know if these are the data points that are best to log, ill probly take out coolant in the future but i just wanted to be safe the first time around. Is the knock acceptable? I have stock 450s, and stock IC for now so is there any tuning i can do? Boost is around .6/7 bar (8-10 psi) is that the max i can run for now? Thanks for help.
Timestamp (us),RPM (rpm),Timing (deg),Knock (deg),CoolTmp (F),InjDuty (%)
25609024,1011,16.0,0.0,213,2.6
25656448,1015,16.0,0.0,213,2.6
25703872,1027,16.0,0.0,213,2.7
25751296,1040,16.0,0.0,213,2.7
25798720,1045,16.0,0.0,213,2.7
25846148,1055,17.0,0.0,213,2.8
25893588,1061,16.0,0.0,213,2.8
25940992,1063,16.0,0.0,213,2.8
25988416,1066,17.0,0.0,213,2.8
26035840,1072,17.0,0.0,213,2.9
26083268,1077,17.0,0.0,213,3.0
26130692,1082,18.1,0.0,213,3.0
26178112,1093,18.1,0.0,213,3.2
26225536,1107,18.1,0.0,213,3.3
26272960,1118,18.1,0.0,213,3.4
26320384,1143,19.1,0.0,213,3.3
26367808,1169,18.1,0.0,213,3.5
26415232,1197,18.1,0.0,213,3.7
26462656,1210,18.1,0.0,213,3.7
26510080,1236,18.8,0.0,213,3.9
26557504,1258,19.1,0.0,213,3.9
26604928,1282,19.1,0.0,213,4.1
26652352,1300,19.1,0.0,213,4.1
26699776,1318,20.2,0.0,213,4.2
26747200,1328,20.2,0.0,213,4.2
26794624,1340,20.2,0.0,213,4.2
26842048,1347,20.2,0.0,213,4.2
26889472,1354,20.2,0.0,213,4.3
26936896,1358,20.2,0.0,213,4.3
26984324,1361,20.2,0.0,213,4.3
27032632,1369,20.2,0.0,213,4.3
27079168,1369,20.2,0.0,213,4.3
27126592,1371,20.2,0.0,213,4.4
27174020,1377,20.2,0.0,213,4.5
27221440,1384,21.3,0.0,213,4.4
27268864,1388,21.3,0.0,213,4.5
27316288,1394,21.3,0.0,213,4.5
27363712,1400,21.3,0.0,213,4.6
27411136,1410,21.3,0.0,213,4.7
27458560,1423,21.3,0.0,213,4.7
27506100,1429,21.3,0.0,213,4.7
27553408,1438,21.3,0.0,213,4.8
27601340,1448,21.3,0.0,213,4.8
27648256,1456,21.3,0.0,213,4.8
27695680,1459,21.3,0.0,213,4.9
27743104,1463,21.3,0.0,213,4.9
27790528,1471,22.0,0.0,213,4.9
27837952,1476,22.0,0.0,213,4.8
27885376,1476,22.0,0.0,213,4.9
27932800,1475,22.0,0.0,213,4.8
27980224,1473,22.0,0.0,213,4.8
28027648,1473,22.0,0.0,213,4.8
28075072,1471,22.0,0.0,213,5.1
28122504,1474,22.0,0.0,213,5.0
28169924,1476,22.0,0.0,213,4.9
28217348,1464,22.0,0.0,213,4.8
28264772,1460,21.3,0.0,213,4.5
28312196,1461,22.0,0.0,213,5.0
28359620,1467,22.0,0.0,213,4.9
28407080,1474,22.0,0.0,213,4.9
28454504,1478,22.0,0.0,213,4.4
28501920,1481,22.0,0.0,213,5.3
28549328,1478,22.0,0.0,213,4.9
28596740,1486,22.0,0.0,213,5.3
28644208,1489,22.0,0.0,213,4.9
28691604,1490,22.0,0.0,213,4.9
28739028,1492,22.0,0.0,213,5.0
28786452,1491,22.0,0.0,213,5.3
28833876,1498,22.0,0.0,213,5.1
28881300,1497,22.0,0.0,213,5.0
28928724,1501,22.0,0.0,213,4.9
28976148,1499,22.0,0.0,213,5.0
29023572,1498,22.0,0.0,213,5.0
29070996,1500,22.0,0.0,213,5.0
29118420,1503,22.0,0.0,213,5.0
29165844,1507,22.0,0.0,213,5.0
29213268,1506,22.0,0.0,213,4.9
29261168,1511,22.0,0.0,213,4.9
29309272,1512,22.0,0.0,213,5.0
29355540,1511,22.0,0.0,213,5.1
29402964,1515,22.0,0.0,213,5.0
29450388,1517,22.0,0.0,213,4.9
29497816,1515,22.0,0.0,213,4.9
29545236,1509,23.0,0.0,213,4.9
29592660,1500,23.0,0.0,213,4.8
29640084,1491,23.0,0.0,213,4.7
29687856,1485,23.0,0.0,213,4.8
29734932,1476,23.0,0.0,213,4.8
29782356,1471,23.0,0.0,213,4.7
29830640,1464,23.0,0.0,213,4.7
29877204,1467,23.0,0.0,213,4.6
29924632,1465,23.0,0.0,213,4.6
29972052,1463,23.0,0.0,213,4.6
30019476,1461,23.0,0.0,213,4.5
30066900,1459,22.0,0.0,213,4.5
30114340,1452,22.0,0.0,213,4.5
30161764,1450,22.0,0.0,213,4.4
30209188,1450,22.0,0.0,213,4.6
30256612,1446,22.0,0.0,213,4.6
30304760,1440,22.0,0.0,213,4.5
30351496,1441,22.0,0.0,213,4.6
30398908,1445,22.0,0.0,213,4.5
30446332,1450,22.0,0.0,213,4.6
30493756,1447,22.0,0.0,213,4.4
30541180,1450,22.0,0.0,213,4.4
30588604,1450,22.0,0.0,213,4.3
30636572,1447,22.0,0.0,213,4.0
30683452,1438,22.0,0.0,213,4.0
30730912,1423,22.0,0.0,213,3.8
30778300,1400,21.3,0.0,213,3.8
30825724,1383,21.3,0.0,213,3.6
30873148,1372,21.3,0.0,210,3.6
30920572,1360,20.2,0.0,210,3.6
30967996,1344,20.2,0.0,210,3.7
31015420,1334,20.2,0.0,210,3.5
31062844,1329,20.2,0.0,210,3.6
31110268,1324,20.2,0.0,210,3.6
31157692,1326,20.2,0.0,210,3.7
31205116,1328,20.2,0.0,210,3.8
31253696,1334,20.2,0.0,210,4.0
31299968,1342,20.2,0.0,210,4.3
31347388,1355,21.3,0.0,210,4.3
31394812,1373,21.3,0.0,210,4.4
31442268,1403,22.0,0.0,210,4.5
31489660,1424,22.0,0.0,210,4.6
31537084,1443,22.0,0.0,210,5.0
31584508,1458,21.3,0.0,210,5.4
31631932,1492,21.3,0.0,210,6.4
31679356,1538,16.0,0.0,210,7.1
31726780,1625,15.3,0.0,210,8.2
31774204,1688,15.3,0.0,210,8.7
31821628,1776,14.2,0.0,210,9.2
31869052,1847,15.3,0.0,210,9.6
31916476,1911,17.0,0.0,210,10.0
31963904,1955,16.0,0.0,210,9.9
32011324,1996,17.0,0.0,210,10.2
32058748,2024,17.0,0.0,210,10.4
32106184,2053,17.0,0.0,210,10.6
32153596,2074,18.1,0.0,210,10.7
32201020,2086,17.0,0.0,210,10.9
32248444,2103,17.0,0.0,210,10.9
32296208,2119,17.0,0.0,210,11.1
32343292,2126,17.0,0.0,210,11.2
32390716,2140,17.0,0.0,210,11.7
32438140,2156,16.0,0.0,210,12.0
32485848,2179,17.0,0.0,210,12.2
32532988,2190,17.0,0.0,210,12.4
32580412,2205,17.0,0.0,210,12.6
32627932,2224,15.6,0.4,210,12.5
32675784,2239,15.6,0.4,210,12.7
32722684,2244,14.9,0.4,210,12.9
32770108,2264,15.6,0.4,210,13.1
32817532,2277,15.6,0.4,210,13.3
32864964,2295,14.9,0.4,210,13.4
32912380,2299,13.9,0.4,210,13.5
32959804,2312,13.9,0.4,210,13.8
33007228,2332,14.2,0.0,210,13.8
33055036,2360,14.2,0.0,210,14.0
33102076,2396,15.3,0.0,210,14.3
33149508,2449,14.2,0.0,210,14.8
33196968,2554,15.3,0.0,210,15.6
33244356,2708,15.3,0.0,210,16.7
33291780,2898,16.0,0.0,210,18.4
33339204,3076,17.0,0.0,210,20.1
33386628,3173,16.0,0.0,210,21.4
33434052,3200,16.0,0.0,210,22.5
33481476,3194,15.3,0.0,210,23.2
33528900,3189,14.2,0.0,210,23.7
33576324,3208,13.1,0.4,210,24.6
33624716,3267,13.1,0.0,210,26.0
33671212,3330,12.1,0.0,210,27.5
33718596,3391,11.0,0.0,210,29.4
33767040,3456,12.1,0.0,210,31.4
33813444,3505,11.0,0.0,210,33.6
33860868,3558,11.0,0.0,210,35.9
33908292,3630,10.0,0.0,210,38.0
33956220,3680,10.0,0.0,210,40.1
34003144,3728,8.9,0.0,210,41.6
34050568,3799,8.9,0.0,210,42.6
34097988,3870,8.9,0.0,210,43.5
34145412,3943,8.9,0.0,210,44.2
34194000,3989,8.9,0.0,210,44.6
34240260,4024,8.9,0.0,210,45.3
34287684,4094,8.9,0.0,210,45.9
34335112,4157,8.9,0.0,210,47.1
34382532,4237,8.9,0.0,210,48.0
34429956,4305,10.0,0.0,210,49.8
34477380,4366,10.0,0.0,210,51.0
34524840,4422,10.0,0.4,210,52.9
34572228,4480,9.6,0.4,210,54.4
34619652,4562,9.6,0.4,210,56.2
34668180,4618,9.6,0.4,210,58.0
34714500,4688,9.6,0.4,210,59.8
34761924,4765,9.6,0.4,210,61.4
34809348,4826,10.7,0.4,210,63.0
34857152,4889,9.6,1.4,210,64.0
34904196,4941,9.6,1.4,210,65.1
34951620,5020,10.7,1.4,210,67.1
34999048,5081,10.7,1.4,210,68.2
35046468,5151,10.7,1.4,210,69.7
35094616,5223,11.7,1.4,210,71.8
35141316,5304,11.7,1.4,210,73.2
35188744,5365,11.7,1.4,210,74.3
35236164,5419,12.8,1.4,210,76.0
35284604,5482,13.1,1.1,210,77.0
35331012,5564,13.1,1.1,210,77.9
35378860,5639,13.1,1.1,210,78.9
35426384,5716,14.2,1.1,210,80.0
35473324,5787,14.6,0.7,210,81.0
35520748,5850,15.3,0.7,210,81.8
35568304,5906,15.3,0.7,210,83.0
35616120,5971,15.3,0.4,210,84.1
35663668,6039,16.7,0.4,210,84.7
35710492,6107,16.7,0.4,210,85.6
35757868,6178,16.7,0.4,210,87.2
35805296,6260,17.0,0.0,210,88.2
35852888,6324,18.1,0.0,210,89.8
35900148,6388,18.1,0.0,210,90.0
35947564,6443,18.1,0.0,210,91.3
35995364,6499,18.1,0.0,210,92.1
36042412,6545,18.1,0.0,210,93.0
36089836,6567,18.1,0.0,210,93.7
36137412,6579,18.1,0.0,210,93.7
36185736,6477,17.7,0.4,210,93.0
36232860,6281,16.7,0.4,210,92.1
36279532,6078,16.0,0.4,210,89.8
36326960,5859,15.6,0.0,210,87.6
36374380,5639,14.2,0.0,210,85.6
36421804,5396,13.1,0.0,210,83.3
36469228,5158,11.0,0.0,210,79.5
36517000,4908,10.0,0.0,210,75.1
