W/F4A33 Auto Trans Parts F/S, Everything is PLUS Shipping and fees. Willing to hear offers on items that aren’t noted as firm.
I will be trying to get some photos and break things down this weekend. Some items are already out and ready to go, most are still inside some parts transmissions.
-1G and 2G Parts:
-1G and 2G Parts:
- 1X Planetary gear set with forward and rev. sun gears - SOLD
- 2X 2G Trans pans - $45 each
- 3X Forward Drums/Baskets (can include new Raybestos Red Stage 1 Clutch pack for additional cost)
- 2X OEM front clutch assemblies. One will come with a used set of Kiggly 5 friction clutch pack - $75 for OEM, $120 for unit with Kiggly 5 friction stack
- 3X OD Clutch assembly (Can be rebuilt and loaded with fresh Borg Warner frictions and Raybestos steels if wanted) - $65 as a core $235 rebuilt with new seals and the BW frictions/Raybestos steels FIRM
- W/F4A33 Low Reverse Clutch Pack- Uses Raybestos stage-1 RED frictions (x6), and Raybestos steels (x5) - $145 FIRM
- W/F4A33 Direct, Forward, and OD friction and steel module. Comes with Kiggly 5 friction front (Direct) clutch pack, Raybestos stage 1 RED Rear (Forward) clutch pack, and BorgWarner Overdrive clutch pack. $350.00 FIRM
- 1X 1g W4A33 trans casing - $125
- 2X 1g W4A33 output shafts -$85 each
- 1X 1g Input shaft - $85
- 2X 2g F4A33 Transmission cases $75 each
- 2X 2g F4A33 front diffs - $50 each
- 2g input shaft - $85
- 1X 2g Valve body (OEM) - $150
