Hi Tuners.
1G and 2G V1 Bump steer kits
If your tie rod ends part number is MB912519 this kit will work for you as they are a direct replacement!
If you have lowered your car and/or want to add alot of caster then these are for you! They also remove any slack a ball joint may have and give ultimate driver feedback to the steering wheel for a more precise feel. Caster makes the connection area drop resulting in out of sync and a massive issue for toe change in steering and cornering/braking! If you are serious about handling then this is something you need.
These feature the same high end, race Chromoly rod ends I always use and will continue to use for strength and quality.
ABOUT THE ITEM
Adjuster shafts a made from EN24T for amazing strength and have the same length internally as an OEM outer tie rod end so no loss of length or threads, spacers are also now EN24T to match and have offset heights for adjustment and washers are included aswel if needed, everything will be hybrid black zinc coated, taper spacer inserts into the knuckle so no need to drill or reem the knuckle out! its what you would call plug and play to an extent.
Hardware will be a 12.9 socket capped bolt and flanged nyloc nut to secure into place.
For installation most of the time these will be placed above the knuckle like oem ones are, for those that are really low then you may try to use below the knuckle!
SETUP is critical to getting correct, the use of a bump steer gauge is best to get super accurate results, a link here walks you through best ways to setup and troubleshoot http://www.longacreracing.com/technical-articles.aspx?item=8162
When i tested my car out (2G), oem tie rods vs my new kit i managed to dial alot if not most of it out all from the fact of lowering my car!
Lowering the car 2" sees a toe of 50 thou (1.27mm) upon compression! this is alot!
Oem tie rods and lowered 1 1/4" produced 32 thou! (0.8128mm) upon compression! Thats also a fair amount
My kit same ride height of 1 1/4" managed to get it to just 9 thou!!! (0.2286mm) thats much better and its also better then stock is at oem heights!
These will ship within 2 days of payment and tracking number will follow once shipment has been done.
Price +£10 to Canada. When paying please include the full address and phone number as not listing them details will delay shipment as i cannot book collection for the parcel!
Any questions please ask
ABOUT THE ITEM
