Old Thread:
Hey all,
tired of collecting all the shifter bushings you need from 5 different vendors?
Now you can get them all from ONE source!
I compiled a set of all the bushings from the complete shifter base to the shifter cables and lever arm on your transmission. All bushings were CNC machined with tighter tolerances than stock to eliminate every single shifter play on your DSM. You will feel the difference!
These will fit all 90+ 1G and 2G DSMs.
Each set will come with an installation instruction, to make the installation easy for everyone.
Price is $190 shipped worldwide!
For the complete set of 28pcs.
If you don't need the complete set, no problem! Each bushing pair can also be purchased separately!
The set consists of:
1. shifter pivot bushings - back/forth (2pcs) $20
2. shifter pivot bushings - left/right (2pcs) $25
3. shifter pivot bushings - lower lever (2pcs) $20
4. shifter cable bushings - interior (4pcs) $25
5. shifter base bushings - interior (8pcs) $20
6. shifter cable bushings - transmission (2pcs) $30
7. shifter cable bracket bushings - transmission (4pcs) $20
8. shifter lever arm bushings + POM guide - transmission (3pcs) $25
9. shifter cup bushing - interior (1pc) $10
Just send me a PM with your order details and I'll get back to you asap.
Hey all,
