For sale 4G63 TD04HL turbo
$115.00
Ad details
TD04HL turbo off a Mitsubishi RVR. This is a dsm bolt pattern turbo and is slightly smaller than a 14b. This would be a good replacement if your 14b has failed. This turbo could use a good cleanup. The turbine housing is cracked as pictured. Maybe you have a good 14b housing you can use. There is no in/out shaft play. Normal side to side shaft play. No wheel damage. $115 shipped OBO
