For sale SBR GT10 Stock Frame DBB Turbo + Wastegate, turbine sock, and boost controller
$300.00
Status
Incredible stock frame turbo. Bought this off Justin a few years ago has maybe 2k of miles on it since I purchased it (with new seals) turbo spools about the same as a 20g but will flow about 50lb. Uses a garret gt30 dual ball bearing chra, you could switch this to t3 with one of the aftermarket turbine housings available. Comes with feed line, rear coolant pipe, and drain, you can reuse your stock front coolant pipe.
The wastegate flapper has been welded shut, there are cracks in the housing they have 0 effect on the spool, I bought the turbo like that from Justin. YOU NEED TO RUN AN EXTERNAL WASTEGATE WITH THIS TURBO!
Also included is a 38mm Turbosmart Ultragate, so you're covered there!
Included Not picture (I will send photos if you want) but included are a Halman MBC and Turbine housing sock.
Price is less shipping and PP fee
talon749
Watchers
