Please Support Rix Racing
For sale REBUILT FP DSM Red Turbo
Sold
$950.00
Status
Ad details
Rebuilt FP DSM Red turbocharger. This unit began life as an old-school Green with compressor damage, so I upgraded the rotor group to be the same spec as the current DSM Red. Compressor is now a billet KTS D547 model which is the same spec as the FP Red wheel at 54.9/76mm, but it is also an extended-tip compressor design so the effective exducer is 81mm for greater airflow potential without sacrificing response. Turbine is a clipped TD06H4 which is standard on the FP DSM Red models. Turbine housing is a ported 7cm2 housing with an internal gate for ease of installation and no additional parts required for boost control. Actuator contains a 1.5-bar spring, so factoring drive pressure and actuator pull the baseline pressure will likely be in the 14-15psi range depending on supporting mods and altitude.
Proper oil supply and drainage is crucial. This turbo must be supplied with no more than 50psi of oil pressure under load or you risk causing oil-related damage to the turbo. Use of a braided stainless filter housing feed with a .075" restrictor is highly recommended....do NOT feed this turbo unrestricted from the filter housing or you risk causing an oil-related failure for which I will not accept responsibility. The oil drain must be as straight as possible, have no kinks, and must not dip below the fitting on the oil pan at any point.
The price is just $950 SHIPPED for this turbo to the lower 48 states only- I cannot ship to Canada or Internationally.
Paypal is accepted; the buyer will be responsible for any fees associated with submitting / receiving the payment. All interested parties can contact me via Private Message here on Tuners or via email at [email protected]. Priority given by order of contact.
