For sale 1g Random leftover 1G bits
$1.00 to $100.00
Status
1 member is watching this ad
Ad details
These are some leftover parts from my 93 GSX that I no longer need. Not looking to make a ton of money off these. Mostly just dont want to throw them out if someone wants them. If your interested in anything make me an offer and cover shipping is all I ask. I also do not have boxes to ship most of these on hand so if you want something it might take me a couple days to get it out to you. I will not ask for payment before its packed and ready to go.
OEM rear left shaft. Needs rebuild.
0.3in wheel spacers. Removed from the rear.
Front strut tower bar. Unknown brand.
Cruise throttle cable. There is a holt drilled into the cover where I temporarily mounted a sensor. The cover is also pretty bent up. Still functions.
Sun visors that need to be reupholstered. Hinges work as they should.
Stock fuel pump.
Shifter bushing. Accidentally ordered this and a metal one. Not worth returning.
Stock fuel pressure regulator.
Front camber bolt things.
Intake Temp sensor bung.
Fuel injector clips.
Front door speaker buckets.
Some sort of aftermarket coolant reservior.
These two pipes.
ABS pump
Front ABS wheel speed sensors.
