For 1990-1999 Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, and Galant VR-4 Owners
  • Join the Community!
For sale 4G63 Performance Part Out and some stock (ECMLINK, FIC, FUEL LAB, more)
$40.00 to $675.00
Ad details
Recently sold my 1GB Laser and removed some of the performance parts to return it to stock. Also have some stock parts lying around. Everything is in perfect working condition. All prices are shipped to your door and all fees included.
Please PM for additional info.
Thanks
  • 1G EcmLink V3 with cable and 1990 Socketed EPROM Turbo ECU (Will need to swap pins 6 and 14 if using in 91-94, reference the VFAQ for more info) - $675
  • 1G homemade Speed Density Harness, plug and play to stock plug, and 3 bar map/GM IAT sensors - $75
  • GM Flex Fuel sensor and Harness - $40
  • MAP Performance 1G stock turbo oil return kit with AN push fittings and rubber hose - $50
  • 2G stock black top 450cc injectors, will need new upper seals - $100
  • 2G Fuel Rail and stock FPR - $50
  • FIC 950cc injectors used low miles, will need new upper seals - $175
  • 1g AWD Walbro 255 HP fuel pump with harness used low miles - $40
  • Fuel Lab FPR With fuel rail return line and fitting used low miles - Sold!
  • Innovate MTX-L Wideband used low miles with original box and accessories - $125
  • Autometer boost gauge with tubing and T fitting - $40
  • Hallman ES manual boost controller - $40
  • Stock DSM 14b/16g wastegate - SOLD
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned VR Speed Factory
