The awesome V2 bumpsteer kit, I have been asked about some more of these so here they are.
Hello everyone and I am back once again with a new product.
full thread with replys here https://www.dsmtuners.com/threads/new-product-v2-bumpsteer-kit-2g-closed.532802/
This is the V2 bump steer kit for the 2G and which takes what I learnt from the V1 kit, This takes that and works around those foundations to make it all around stronger, better and all around complete custom setup.
new benefits include,
* 1 piece outer shaft (EN24T)
* revised outer spacers which offer an easier outer dial of adjustment and over a wider range
* 1 piece shaft now allows you to go 1.25mm closer to the steering arm meaning more can be dialed out the lower your car is
* upgraded outer rod end size which adds more strength then previous (still the high quality kevlar/telfon lined chromoly units I always use)
* strong middle adjusting shaft
* brand new high quality inner tie rod end which is stronger then the oem units
This kit comes as a full replacement from everything from inner to outer tie rod end! its a 100% complete kit for you and it even comes complete with brand new inner rubber bellow covers so everything is covered and no trips to the hardware or parts store needed!
the shafts and adjuster will be plated for corrosion resistance.
this kit is not designed for cover boots over the rod ends but you can if you wish buy these to give some protection https://secure.chassisshop.com/partlist/15344/
Price is £368 Shipped. please read the details on the next line!!!
!!!!! These will be ready I hope by end of Feb 2022 and can ship out as soon as I have them back from plating and put them all together so either will ship at the end of Feb or start of march time as a current estimate!
I am making 20 car sets but can only ship 10 sets out once ready due to low stock levels with the inner tie rod ends so the rest can be pre paid for to secure your item and the remainder of the inner tie rods should be in by April and can ship as soon as they arrive into me. !!!!! any questions on this part then please do ask and confirm
US lower 48 shipping INC, anywhere else please PM me for a quote, Canada tends to run a small amount more ( £10-15 depending ) but not much more.
NOTE Payment is in GBP Pounds and when sending payment please include your full address and phone number along side your dsmtuners screen name please so its easier to track incase of a question. no phone number delays the shipping process so is critical its added as a note in paypal
Thank you
View attachment 620195 View attachment 620197 View attachment 620198 View attachment 620199 View attachment 620200
Thank you
