FIBA Motorsport Stainless Steel Front and Rear Rotor Dust / Cooling Shields
These are some nice Stainless Steel Duct / Cooling Shields that will be a replacement for what you may have already taken off or rusted away but since these are STAINLESS STEEL you will NEVER have to worry about corrosion NEVER EVER again!!!
I designed these for a few reasons, the main reason is when you upgrade brake size like Evo Brembo calipers you no longer get to use the Front or Rear shields anymore. The other reason is the OEM ones are corroding anyway and rotting from age, salt and are also discontinued!
These have a few great benefits for using them which include:
• Rubber parts protection (ball joint coverings)
• ABS sensor protection from heat
• Dust control getting onto everything else
• Water protection getting onto the rotor surface which creates a delay in braking performance
• Most importantly, it aids in cooling also keeping more air along the surface of the rotor itself
• THESE are also MODULAR! Meaning if you start off on a 320mm rotor and later go to 350mm or larger, all you will require is a replacement outer shield! You keep the middle section and this is just part of the easy swap over process which also helps keep upgrading costs DOWN even more
Should you wish to order multiple sizes PM me for this as it’s not available on my form!!!
To top it off I also now have specific cooling ducts for the Galant Knuckle/Brembo setup which is a direct bolt on. The cooling ducts are ALSO Stainless Steel construction and the use of 2” cooling hose is used due to space coming from the backside of the caliper out.
These can come in either a DIY setup as ducts on their own or a full package which includes Ducts, High temp hose and ducts for the front bumper which are universal fitment! And to finish it all off Stainless Clamps.
Universal ducts are made from ABS plastic and come in a small or large design (placement of these will be up to you and space available).
I have 3 dust / cooling shield options available so please read carefully the details:
• 2G DSM OEM knuckles
• Galant knuckles
• EVO 5-9 knuckles
DSM/Galant are on this form so please fill it out if you wish to order and then send it through ready for the invoice;
Installation is simple and each KIT comes with ALL NEW Stainless hardware! No more rusting bolts either here in the quest for perfection!!!
INSTALLATION
• Fronts simply bolt on! It’s that simple
• Rears will require you to clean up the old spot welded sections and then once placed correctly mounted up then you will drill some new holes for the plate to bolt onto and that’s it. Nothing more to do
NOTES…
• EVO owners -- IF you wish for the EVO dust shield/duct, then please message asking for this as I don’t have a form for it (price and rotor size prices in the form will still apply though). Bulk shipping is doable so ask for this quote to combine orders!!!
• 1G owners -- please NOTE that I have not forgotten you! I’m working on them shortly so will have those up when I can complete them. Another post will go live once done. So, follow the page and keep an eye out for the post
• OEM GSX SPEC restorations ONLY -- IF you wish for an OEM-sized setup please get in touch and I can adjust the design to accept the smaller rotors for the front setup. I was unable to make them work with the smaller GST rotor size! so GSX sized only for OEM restoroations. The Rears will still work on the OEM sized rotors. While this is on the form it’s not yet done unless I get requests for them!
---------- ( PRICES ) ----------
Starting From £150 shipped to the lower 48 USA. Other locations + Canada please message for shipping prices
Prices are all on the form for you which includes the size differences and extras + kit options so please select what parts you wish to get and submit it over to me. If you wish to add extras or EVO kits then I can add this on once the forms filled out!
Any questions as always, I am here to help and advise so ask anything you may need to know details on.
I will close this initial group buy on the 7Th Oct 2023 so I can get these made up. Cooling ducts ordered will take a bit longer to ship out so please be aware of this detail ahead of time.
Thank you and as always please follow my page and share if you can to help me serve more DSM members across the world!
#fibamotorsport #fibamotorsports #InnovationStartsHere #damtuners #dsmnation #dsmrestoration #dsmftw #dsmnewproduct #makedsmsgreatagain
REARS have now been completed in 3 sizes from OEM 262mm, Evo 300mm and Evo X 330mm
More shields going out and some ducts also!
