Since nothing is available anymore for the 1G rear frames This was open to a lot of ways to proceed here. Thankfully I am great at coming up with a solution!
Please fill out this form and submit it, once done I can then invoice you for these. I will run these along side the OTHER 1G products.
These are the STOCK subframe mount inserts. These became a product as a halfway between new mounts or solid alloy units which were going to be too stiff and transmit A LOT of noise into the cabin.
These keep the stock rubber inside both frame sections and mount upon those to offer support and stiffness so you get the best of both worlds.
The INSERTS are made from TPU, These will offer increased stiffness and support to stop the frames from shifting and make things a lot tighter back there while keeping NVH down more vs solid and alloy bushes.
To add to these inserts upper and lower load spreader plates were required, These are in stainless steel for long-term corrosion protection while doing their job to support the loads across the bases.
This KIT is quick and easy to install, everything simply inserts into place, and once mounted nothing else is required. NO having to remove the old bushes or remove the diff and axles which can take time and make a mess.
* Move the rear exhaust section out the way
* Simply lower the subframe in place.
* Remove the OLD parts
* Slip these in
* Mount it back up again! JOB DONE!
ANOTHER simple install with great results!!!
1G AWD Rear subframe insert order form
Please click the link to complete this form.
form.jotform.com
* Slip these in
