For sale Freelancer ***** NEW PRODUCT RELEASE ***** 1G - 2G stainless steel fuel filler necks ( OPEN )
Full stainless replacement so you can remove the rotting OEM ones
£362.00 to £385.00
Status
10 members are watching this classified ad
HELLO Tuners!!!
Once again I am back with another NEW product ready to release and this times BOTH for the 1G and 2G owners. :rocks::rocks::rocks:
I know some of you have been waiting for these for a long time and I'm sorry for the delay on these being released.
WHY DO YOU NEED THESE FILLER NECKS??? Well the stock ones are now very very old and they are corroding away and starting to leak which is a huge problem for fumes and fuel drips, you can no longer buy brand new anymore and if you find a decent used one how long till that leaks again! with Ethanol eating away at the metal its just a matter of time before you need another one and by then the parts will be FAR harder to find and locate good parts!
This WILL SOLVE all those problems and likely to out last the car once replaced so be sure to future proof you're car!
please note that ALL caps will come in raw alloy and with a SS Ball bearing for the vent in the cap and offers roll shut off protection just incase. this allows the system to also have maximum air fluctuation in the tank for pressure relief plus works better incase the factory breather is clogged up or does not work.
All the made parts like neck, cap, mounting tabs and mounting rings are all custom CNC machined or laser cut for precision!
all tubes will be hand cut and finished and fully back purge TIG welded
Details below for each version.
* 1G AWD
* Will come with main filler neck which has 1x 10 AN bung welded on
* cap with roll over protection/BB
* outer mounting plates under the filler flap
* chassis breather plate with tube.
This mounts exactly the same as stock and also mounts the cover in place also.
1G DOES NOT COME WITH
The filler neck requires you to finish the breather system off to you're desired specs and I have left this open to you're choosing and what you like best.
Basics would be 5/8 breather hose, 1X 10AN to 16mm barb fitting 90 Degree, use of the stock or gates 90 degree hose for the tank.
*2G
* will come with the main filler neck and has 2x 10AN bungs welded on
* flexible filler hose to mount to the tank
This mounts exactly the same as stock using 1 bolt and can even use the stock metal cover plate should you wish to do so!
2G DOES NOT COME WITH
Any AN fittings for the bungs nor any breather lines, This will be custom to you're specs and liking.
If you require only 1 bung to be used then you can cap the second off with an AN cap safely.
Will come as a brushed effect finish OR optional black stone chipped paint for a stealthy look if you require it ( wheel area ONLY ) cap and top side will be left in stainless / alloy finish.
the price will be as always in GBP £ and is shipped the the lower 48 USA so any where else outside of those locations please get in touch for a shipping quote
I currently only have 20 caps made but if I require more I will make those to cover what I need. depending on volumes I may split the order and so the 20 first and then come back to the remainder ordered.
Shipping has now been reduced to bring the total costs down a bit. its now an economy ( 5-7 days ) service and removes £25 of shipping charges
the new totals as current as below!!!
Price for the 1G AWD is £362 shipped
Price for the 2G is £385 shipped
if you require the black coating then please add +£25 for the prep and painting
please fill out the form below specifying 1G / 2G
ANY questions please ask or PM me if you require help
Thank you for the continued support of me and my items for you all! I appreciate this greatly and will continue to grow with your support
Bobby
Frequently asked questions
I have one 1G unit ready made to go! In raw finish it can be packed and shipped with in 2 days.
Black costing can be added but delays a few days for the process.
Avoid the 2-3 week wait times normally had with order them as they are made to order.
A few have shipped today and some more over the next few days for both 1G and 2G units!
Thank you all for the support and i really hope you all enjoy them! Another thing you wont have to worry about rusting away ever again!
  • Like
Reactions: DreamChaser7
DreamChaser7
DreamChaser7
Stoked to receive soon! Just wish I was anywhere close to installing. All in do time. Thanks Bro!
Hey all, nearly ready to start shipping these shortly.
Just waiting on some bolts for the 2G that were on back order bit due in this week.
Just adding a few pics of the ones I have made currently in both stone chip protected and brushed effect.
They just need a final rinse and then can be packed ready to start shipping!
  • Hell Yeah
Latest questions
Looks great Bobby! You don’t have a pic of one with the black stone chip coating do you?
DreamChaser7
DreamChaser7
Bobby I filled out the form in the link, but saw no where to pay. What is the next step here for the pre-order?
EC17PSE
EC17PSE
I will send the invoice on the weekend.
fourgsixty3
fourgsixty3
I filled out the form and sent the money. Hope that's ok Bobby and I didn't mess up the process.
EC17PSE
Freelancer Classifeds
Watchers
10
Discussion
8
More from EC17PSE
More in Freelancer Classifeds
