I'm looking to sell my 4G63 6-bolt flywheel + new Mapco clutch disc + Mapco pressure plate. I was going to use the set with my 4G63T, but it doesn't hold the power, so I upgraded to an aftermarket flyheel & clutch combo and I don't need this one anymore.
The flywheel is 280 mm in diameter and it has 110 teeth so it's good for either a 6-bolt FWD Eclipse or AWD Galant. It's also perfectly balanced and freshly resurfaced. It has new pins to locate the pressure plate installed.
The clutch friction disc and pressure plate are both brand new from Mapco.
The clutch disc is 215 mm in diameter and has 20 teeth for the transmission input shaft.
The set is only good for n/a 4G63s, it does not hold 4G63T power.
Ready to ship from Slovenia.
