I'm leaving the community for various reasons, so I'm selling all the parts I've collected. All parts are OBO unless otherwise noted. Buyer is responsible to cover Paypal fees or send as friends/family. I will not pay the fee. PayPal or cash only.
I will ship parts at the buyer's expense. Buyer is also responsible to get their own shipping quote. I won't get the quote for you as I'm too busy at work and can't have my phone their anyway, and my work hours don't work with normal business hours of the shipping companies. My ZIP CODE is 80817, that is all you'll need for the quote. If i get asked to get you a quote, you clearly didn't read this and I won't reply.
All parts are 2G Eclipse turbo parts unless specified.
Larger items might be best as local purchase only. I will consider all fair offers, but all prices I have listed are firm.
I'm not in a big rush to sell everything, but whatever doesn't sell in a few months will get trashed/recycled.
Parts sold will be removed from the list.
More pics on request, please PM with questions.
Body:
2GB OEM bumper inserts
2GB OEM rear bumper $200.00
2GB OEM side skirts $200.00
2GB OEM high wing (×2)
2GA Talon front bumper
2GA Talon rear bumper
2GA Eclipse front bumper
2GA Eclipse rear bumper
2GA Eclipse side skirts
2G OEM Eclipse tail light set
2GB fog lights
Door glass - (×2 sets, both sides)
Front wiper motor assembly
Windshield cowl plus the weather strip
Talon tail light center garnish
OEM power side mirrors
License plate frame from the Shootout - $25.00
Interior:
Black dash $200.00
Coupe A-pillar pod for 3 gauges
OEM shifter cables (×2) $200.00 each
Rear cargo cover (×2)
Grey dash (×2)
Grey leather rear 50/50 split seats
Carpet
Trunk carpet
Trunk floor
Black Dodge Avenger center console and side panels
Drivetrain:
95-96 manual T-case $500.00
97 GST manual trans $700.00 Local pick-up only
GST front axles
AWD rear open diff $200.00
New Clutch slave cylinder
New steel-braided clutch line $100.00
Fidanza 6 bolt AWD flywheel with new (0 miles) friction plate $300.00
Fidanza 6 bolt FWD flywheel $150.00
ACT 6 bolt AWD flywheel
Throttle pedal
Brake pedal
Clutch pedal
Engine:
Engine has 0 miles, 0 start-ups, has been placed in the car a couple times for mock up.
6-Bolt short block w/2G head (head and block were both decked and hot-tanked) $4000.00 Local pick-up only
Includes:
All seals and gaskets have been replaced, along with most of the bolts
Brand new Oil pan
OEM crank-polished
King main and rod bearings
Eagle I-Beam rods
Weisco 0.020 over 9.0:1 pistons
Balance Shaft delete with OEM bearings and stub shaft
OFH is the external oil cooler version
OEM head gasket
OEM valves
New OEM valvetrain
New OEM 3G lifters
New valve seats
Kelford 272/272 camshafts
HKS Cam gears w/ARP Cam gear bolts
HKS timing belt
New OEM timing tensioner
New OEM starter plate
New OEM Hyundai 6-bolt timing cover (modified for 2G engine mount)
Clear cam cover (no-name)
Modified 2G engine mount for 6-bolt usage (has new bolts installed)
OEM intake manifold (×3)
Custom CNC'd aluminum spark plug cover $100.00
OEM rebuilt throttle body with New IAC motor
Injen Intake pipe $100.00
Bare 7 bolt engine block w/girdle - needs cylinder bore job
Bare 2G head - has 3 broken exhaust studs, otherwise fine
JE standard size forged piston set - new in box - $600.00
Suspension/Handling:
DC Sports front strut bar (non-turbo version) $200.00
Front subframe
AWD rear subframe
Front wheel knuckles
Miscellaneous Parts:
AWD fuel pump, tank, shield, and straps - sold together
2G non-Eprom ECU (×2) $100.00 each
Full lock cylinder set with key
OEM exterior door handles (2 sets)
Magen turbo back 3in exhaust
2003 Diamante VRX steering wheel $100.00
New A/C compressor $300.00
New A/C evap drier
Spare strut towers, no rust, great condition - one per side $100.00 each
Body wire harness
Talon body harness from ETACS to fuel pump and rear
Talon Swirly wheels with tires. Tires hold air, but are at 3/32 - $200.00
Eclipse optional chrome wheels. 1 holds air - $200.00
New heater core in air distribution box - $150.00
OEM spare wheel/tire (x3)
Good steering rack w/o inner or outer tie rods
Body:
2GB fog lights
Interior:
Black dash $200.00
Grey dash (×2)
Carpet
Trunk carpet
Trunk floor
Drivetrain:
GST front axles
Throttle pedal
Brake pedal
Clutch pedal
Engine:
Includes:
Brand new Oil pan
OEM crank-polished
Eagle I-Beam rods
OEM head gasket
OEM valves
New OEM valvetrain
New OEM 3G lifters
New valve seats
HKS timing belt
Front subframe
AWD rear subframe
New A/C evap drier
Body wire harness
