Hello
Deciding to go a different route with my car, some of the parts need to be removed which I will be doing over the next few days and will post updated photos then. I’m located in Toronto Canada but willing to ship to the US as long as buyer pays shipping and fees. Open to offers on all items below.
- FP Green with welded flapper, has about 200km on it.
- Tial 38mm gate with STM EWG recirc pipe. Has maybe 50km on it
- FP manifold, been painted with high heat Por-15
-FIC 1100cc injectors. I’ve used them for 200km but were bought used. No issues, previous owner said he had them flow tested and cleaned but can’t verify
- 1g NT throttle body, seals were replaced. Set screw has been changed at lever to a larger bolt
- Evo 3 intake manifold, painted in high heat Por 15 paint
-CX racing fmic setup. Comes with mounting bar, intercooler pipes, couplers and t clamps. Box flange is setup for an HKs, small pinhole leak which is why black putty is seen so it is sealed. Two additional ports added on pipe by tb, one was used for methanol, other for speed density. Can easily be plugged off with a bolt. Used for 290km
- ARP main studs, new in opened box
- FP silver cast short ram intake with k&n filter. Comes with coupler to connect to an fp turbo
- 1 reclining recaro rep seat in red. Comes with slider. Previously been scotch guarded
- valve cover. Has one broken bolt hole for injector cover. Was painted with wrinkle spray paint
- Eprom ECU with ECMlink and cable installed. Was using it for the above setup
