For sale 4G63 BUILT 4G63 7 Bolt Engine
Sold
$1,950.00
Status
BUILT 4G63 7 Bolt 2.0 Engine $1950
( pick up in 08080 NJ )
Wiseco Pistons 9:1 20 over
Eagle Connecting Rods
BC 272 Cams
BC Springs & Retainers
BC Cam Gears
ARP Head Studs
Balance Shaft Delete
* oil pan will need to be resealed as I have it just bolted on so it can be inspected if desired
* also repacked the oil pump gears with assembly lube to help build oil pressure properly on the next start up
* just under 1200 miles on build
Latest questions
I can't buy this since I live in California, but is this a split thrust bearing block (98/99)?
jersygsx
jersygsx
No standard 7 bolt
jersygsx
Discussion
Expired
Location
New Jersey
More from jersygsx
