Please Support Morrison Fabrications
Please Support STM Tuned
For sale Freelancer ANNOUNCEMENT ***** Products to be released in 2023 by Bobby / FIBA Motorsport *****
Just a place to mention about up coming releases of parts for 2023 and plans with the abilty to discuss here
£1.00
Status
23 members are watching this ad
I have some NEW items coming out very soon that are NOT even on my list!
Be sure to keep an eye out and follow my posts here and on my Facebook group for when these drop!
Small progress but still progress for NEW parts being produced for us ALL
One member found this helpful.
Nic_Di_Censo
Nic_Di_Censo
cant wait!!!
I have started to work on the rear knuckle shock pins! These are all good and am now proceeding to make a batch.
I ended up doing these also in EN24T for strength and will be hybrid plated. The reason i swapped materials was at the time I was looking into these the duplex stainless was cost effective enough to make it worth while! But all of a sudden something happened with Ukraine and the duplex went up loads! Making it impossible to use! I mean it also affected the prices of my EN24T but not as much as the duplex SS!
So you will still have a great super strong shaft and the hybrid coating will last alonggggg time still so no worries on that part!
This is the first OEM part I'm working on.
fourgsixty3
fourgsixty3
Fanfreakintastic as always Bobby.
Hey all, just posting to gather some in site as to what order people would like things to come out?
let me know and I can look into the main wanted parts a lot sooner!
Thanks
  • Like
Reactions: fourgsixty3
TommyDSM
Front Upper Control Arms! :)
EC17PSE
EC17PSE
@fourgsixty3 the drip rails are something thats worked on in the back as its a slow process on those. In between i cannot do much.
Nic_Di_Censo
Nic_Di_Censo
Front upper control arms please!!!
  • Like
Reactions: chinola69
EC17PSE
Car Cannibal
1g rear calipers = Huge future market here, rear AWD caliper cores are drying up, they suck and seize far to early.
If you can get these to be a bolt, fit a common big rotor, be a 4 piston caliper with e brake, this would be a huge hit moving forwards and save the rear cores market.
I got your neck and tie rod ends but this rear 1G caliper, your fab jewel if you pull it off.
all black 4G63
all black 4G63
I agree they will sell out
This is awesome! I’ll be checking daily for an update on the Upper control arms
Nic_Di_Censo
Love all the innovation.
If only Bobby could post the prices in $USD so we Americans can feel the pain up front.
EC17PSE
EC17PSE
I used to work in dollars, but it started getting hard to keep up with the rate changes and i kept losing out on parts when the rates swapped against me. Since i buy and have everything in £ its easy to let paypal give a current conversion to the current rate for dollars. Its much easier this way and is easy to check vs oaypal or even xe as a quick idea on price.
GST with PSI
GST with PSI
No worries, completely understand. Just giving you a hard time :thumb:
DSM98GSX
DSM98GSX
GTS! (Google that shit)
Im interested on a 1G rear Calipers!!!
Fantastic work! I’m interested in preordering some items.
  • Like
Reactions: EC17PSE
EC17PSE
EC17PSE
Thank you for your support on the items.
EclipseOfTheHeart97
EclipseOfTheHeart97
Looking forward to see your drip rail solution!
I still wonder what happened to the original machine/s that cast the rubber on the stainless steel. Did it just get decommissioned and recycled!? Or it's in a junkyard in Japan somewhere?
This is great I would be interested in the rear calipers for sure!
  • Like
Reactions: EC17PSE
EC17PSE
EC17PSE
the 1G rear calipers are going to be some time off yet. im going to draw up the mounting on the trailing arm and go from there. I have had a few people ask for a 1G rear option and I dont see it being a problem to do just got to put the work in to get it right and then can match my fronts perfectly that already work on the 1G's already so finally a nice complete setup
all black 4G63
all black 4G63
hey how's the rear calipers coming?
Damnit Bobby. My bank account is shrinking just reading this. I want it all, ok maybe most of it. 😁
EC17PSE
EC17PSE
@Car Cannibal @Turbo_Timmy incase you not been on or misses it the filler necks are now love and on pre order so i know how many of each kind to work on.
alexr254
Really need backing plates for rear discs. :)
EC17PSE
EC17PSE
@alexr254 as in the 2G handbrake backing plates?
