Black exterior, grey cloth interior.
Engine 2.3l stroker forged internal 6 bolt
-Eagle chromoly 100mm stroker crank
-Eagle rods
-Wiseco 8.8:1 .020” stroker pistons
-Clevite bearing
-Torque plate honed
-Main line honed
-ARP headstuds
-Mitsubishi MLS headgasket
-New OEM Front case/oil pump gears/BS elimination
-New OEM oil filter housing
-New OEM waterpump
-New OEM timing belt
-New OEM timing pulleys and hydraulic tensioner
-All new OEM gaskets
-New knock sensor
Cylinder Head
-All New Valves, guides and valve seals
-NEW OEM 3g lifters
-Super Tech high tension single valve springs
-Titanium retainers
-FP3X intake and exhaust cams
Exhaust/Turbo/Wastegate
-Manual HBC
-EVO3 manifold ported (fastened down with all new OEM hardware & stainless gaskets)
-Forced performance 3052 ball bearing turbocharger
-Turbo & manifold ceramic coated black/compressor housing cerma-chrome
-FP stainless turbo oil feed line(.030" restrictor w/ 10micron filter)
-FP turbo oil drain line
-FP 2.5inch v-band o2 housing
-Tial 44mm v-band wastegate w/ custom 304 stainless dump tube
-Custom 4inch 304 brushed stainless steel exhaust (very straight route)
-4inch stainless steel magnaflow straight through muffler
Intercooler/Intake
-Custom 4inch 304 stainless intake pipe with K&N filter
-Kinetic front mount intercooler (core size 24" long, 12" high and 3.5" thick)
-Custom 2.5 inch 304 stainless intercooler piping
-Tial blow off valve w/ v-band clamp
-Magnus motorsports sheet metal intake mani. w/ nitrous bungs
-Phenolic intake manifold spacer
Fuel/Management
-Walboro 255 fuel pump
-New OEM mistubishi fuel filter
- AN lines from custom welded stock fuel rail
-Aeromotive Fuel pressure regulator
-FIC 1000cc injectors
-AEM standalone engine management (gm5bar map, GM intake air temp.)
-PLX m300 wideband oxygen sensor unit
-Custom dyno tune (fine tune using load cell tuning technique )
-Autometer electronic gauges (boost, fuel press, oil press, coolant temp)
Miscellaneous
-17x8 Enkei RPF1 15.5lb each
- Bridgestone Potenza RE030 235/45-17 Tires
-Snow Performance meth injection
-DC stut tower bars front/rear
-B&M short throw shifter
-Southbend clutch
-ACT light weight flywheel
-SS braided clutch line
-New clutch fork, pivot ball, and throwout bearing
-Polyurethane engine mounts
-Non-cruise control throttle cable/ cruise control removed
-Air conditioning removed
If you have any questions or counter offers, please message me.
-Eagle rods
-Clevite bearing
-Torque plate honed
-Main line honed
-ARP headstuds
-New OEM waterpump
-New knock sensor
Cylinder Head
-NEW OEM 3g lifters
-Titanium retainers
-Manual HBC
Intercooler/Intake
Fuel/Management
Miscellaneous
-Southbend clutch
