PLEASE READ FULL AD
Sent one of the most rusted chassis I've ever seen to the junkyard this week but I tried to pull everything that might be useful for a 20-25 year old car. It was a 95 GSX that I'll be using most of the parts from for an awd swap. Most everything else that was able to be removed from the car is available so let me know what you need and I'll check the stash. Please keep in mind I tried to price things as best I could but everything is "or best offer" so don't hesitate to offer what you think is reasonable, I cannot be offended being offered money for things collecting dust in my storage unit. Parts consist of:
-Interior pieces, I have back seat seatbelts, sunroof switch and cover, glovebox door/compartment, etc.
-Also have most dash bezel items like vents and vent dials, fog/mirror/cruise control switches, vent bezel with hazard switch, etc
-Hatch with glass and interior plastic $130, includes spoiler end pieces with brackets.
-Wiper cowl, all tabs intact. $10
-Sunroof glass $20, best used for a broken replacement due to rust.
-Tail lights, no center section $60. Passenger side has small crack but nothing missing. Tabs good.
-2g Headlights $40, foggy and yellowed but functional. Some broken tabs.
-Reverse lights/housings $10
-2 Fuse boxes from under the hood cut from the harness, 1 fuse box in driver side footwell without pigtails/relays
-Driver side window/lock switch $30
-Stock ECU $130
-Mirror/Fog lights/cruise control switch panel $20
-Front 2 piston calipers with pads and rotors $100. Probably should be recoated, and get new pads if not rotors as well.
-Stock 1g intercooler $35
-2g MAF sensor $20
-stock intake manifold with EGR blockoff $40
-Power transistor ptu $30
-Misc engine and trans mounts (manual)
-BAD bottom end. This is the bottom end of the donor motor the head was pulled from. Has a knock and will need a rebuild but the cylinders look good. Again this will need a rebuild.
-BAD FWD transmissions. I have 2, 1 that's locked out of 4th and one that grinds going into second. Will need rebuilds to use.
I'm sure I'm forgetting a ton. Going to do my best to add prices asap but I have to do some research because a lot of these items I'm not really sure what to ask or what their value is. I'll be updating with more detailed info over the weekend as well. So in the meantime shoot me an offer if you see something you want or if you don't see something feel free to ask me and I'll check if I have it. I will only do pick up for the big items to 21122, I'll meet for the right price within a reasonable distance. Happy to provide more pics on request. Prices are best offer plus shipping and PP fees. Thanks for looking!
Things I have been asked for and realize I DID NOT PULL or are NOT AVAILABLE otherwise:
-OUTSIDE DOOR TRIM/SIDE SKIRTS/CORNER CAPS (broken/not worth pulling)
-Fuel sending unit (used for another car)
-Front Seats and Seatbelts
-AC blower
-Hub and lug set
-Stock Radio
-Wheel well splash guards
-Sun Visors
-Door stops
-Sunroof shade
Items sold/pending:
-Interior plastic/trunk interior, rear seats
-Door cards/mirror trim
-Doors (SOLD)
-Mirrors (SOLD)
-Stock head (SOLD)
-Steering column cover (SOLD)
-Passenger window/lock switch (SOLD)
-Ignition and lockset, ignition light ring, ignition position switch (SOLD)
-Valve Cover (SOLD)
-Battery hold down (SOLD)
-Hood and Driver fender (SOLD)
-Interior fuse box with relays and pigtails (SOLD)
-2g Stock throttle body (SOLD)
-Dash gauge cluster (SOLD)
-2g Manual shift cables (SOLD)
-2g shifter base (SOLD)
-Stock ECU $130
-2g MAF sensor $20
-AC blower
-Hub and lug set
-Stock Radio
-Sun Visors
-Door stops
-Sunroof shade
Items sold/pending:
-Doors (SOLD)
-Mirrors (SOLD)
-Stock head (SOLD)
-Valve Cover (SOLD)
