I have 2 thrust bearing, and a 95 7 bolt motor I am tearing apart and selling. If you need any stock motor parts, low miles let me know!
I have a split thrust 7 bolt block. Cylinder bore are roughly 85mm. A rod bearing was installed incorrectly on rod #3. The mains, mating surface, and cylinder bores seem to be in very good condition. Matching bearing girdle, with only 3 main bolts. You will need a new set of main bolts/studs. I can arrange to have machine work done to the block before shipping at buyers expense. Or 200+ shipping the way it sits. I also have the rods/pistons and crank that was in this motor.
