Hey guys, up for sale is a set of brand new 2G calipers w/ brackets. It's important you know right at the beginning, that the threads for the bleeder on the left/drivers caliper is stripped. It came this way from Centric. I don't know how you'd fix this, or if a simple cleaner tap would solve it, but the bleeder screw will thread in, it just won't tighten. I took a picture of the threads and the bleeder itself so you can see it. I can 100% confirm the bleeder on the right side caliper/passenger caliper is perfectly fine, and tightens like it should/isn't stripped.
With that said, I'm pricing these essentially as cores. I'm located in Pensacola, FL 32526, and I want $50 plus shipping for these.
IF you are comfortable with it, and think you can handle rebuilding calipers, I have two extra 2G calipers that I was keeping as cores that you can probably use the parts from these new calipers and make brand new. I will throw the two extra calipers with brackets in for $25 extra. So you'd have four 2G calipers and four brackets total.
Hit me up via PM if you're interested. These FS ads never tell me when someone comments so if you comment and I don' respond, send me a private message!
PS - The little adapters on the back of the caliper are some inverted 45* flare fitting to M10x1.0 male thread adapters, and they will not be included unless you want them, because they don't actually seal with 1G style flare fittings. Calipers come with new brake hardware and everything except pads. New brass crush washers included as well.
