1g or 2g TB elbow. Mild steel. Thick flange and tig welded. Have the fixture someplace for these. Used to use these elbows in both 1g and 2g upper IC pipe kits in the 90s. They also work well for a custom upper pipe that sits low over the trans and IC outlet is to the side of the radiator through the core support.
