These replace the 4 soft rubber bushings in the k-member. The original bushings were designed to reduce noise and vibration, however are soft and compliant, allowing the front suspension to move under hard cornering, braking, and acceleration. This alters geometry, alignment, reduces grip and promotes wheelhop. Furthermore after 30 years the original bushings have had it! They are worn out and ready to replace! We have creates a solid aluminum replacement that will greatly increase the stiffness and rigidity of the system. These tap right in with a slight press fit after the originals have been removed and the holes cleaned up. $150 shipped! More Info here http://whiteshedspeed.com/1g-dsm-solid-front-subframe-bushings/
