For sale 1g Drag Build part out
Closed
$1,111.00
Status
This ad has been closed.
Status
4 members are watching this ad
Ad details
ALL ITEMS MUST GO CASH OBO
SHOOT OFFERS IF ITS STILL LISTED
ASK FOR ANY PARTS
COMPLETE DRAG SETUP PART OUT
Text 3304130020 for quicker reply
Chassis
1gb 92 eagle talon tsi
Complete bushing kit installed including rear subframe and trailing arms
Rear battery relocation
Megan racing Lowering springs
2 piston front calipers
Ebc red brakes
Cnc brake lever
AEM AFR gauge
Boost, water, oil press gauges
10k rpm tach mounted
1g ECM LINK ECU W/ Speed Density
Longblock $4750 obo
Manley turbo tuff I beams
Wiseco 10:1 pistons
Balanced stock crank
ARP L19 studs
Acl tri glide bearings
Kiggly beehives
Kiggly girdle
Kelford 272/272
Supertech valves
Black top cam sensor
Stock green CAS as well
Spare 6bolt block $200
Driveline $4500 set obo
Shep stage 4 trans
ACT twin disc clutch and flywheel (2 passes)
Shep t case
Shep rear diff LSD
4 bolt rear setup
Shep 4bolt diff and axle set $400
Rebuilt tcase $250
Rem evo 1-3 gearset $700
Stock driveshaft new bearings $100
Front axle set $150
JM fab fuel cell 7gal with sending unit $700
A1000 ext pump $300
AEM rail $100
FIC 2150cc (brand new from cleaning) $650
Aeromotive AFPR w/ gauge 100
HX40 7blade billet wheel $750
DNP t3 manifold $150
Tial wastegate 38mm (25 psi spring) $200
EPROM ECU with DSMLINK speed density $800
ETS 5” intercooler (can include short route piping) $850
Stock intake with 1g throttle body $100
Mishimoto 1g rad $100
Rota slipstream with slicks mounted $1000
STM CnC staging brake $150
AEM AFR Gauge 100
Auto meter gauges (10k tach, water, boost, oil pressure) $300 set
  • Like
Reactions: turbomister2
Latest questions
is it ECM link v3?
