1996 Eagle Talon TSI. $9500
87,229 Miles ( will go up some )
5spd LSD Rear
Clean title in hand
NO TRADES
- New OEM timing belt + tensioner
- New Intake/exhaust manifold gaskets
- New water pump + OFH Gasket
- New NGK Plugs + wires
- New Battery + Terminals
- New Fuel Pump + Fuel Filter
- New PS and Alt Belts
- New silicone turbo/coolant hoses
- Cerikoted Heat Shields
- New lower front control arms
- New Exedy OEM replacement clutch
- NEW OEM fork, pivot ball, TO bearing
- NEW Turbo Drain Line+gaskets+hardware
- New stainless steel clutch line
- No name 3” exhaust
This car is ready to be driven and I currently drive it a few days a week. The paint is not perfect but overall is an awesome car. The engine runs great, tires are good, and the trans shifts smooth into every gear.
Please PM if you’re a serious buyer AFTER you have your finances and transportation figured out. I’m located in 08096 NJ, the car is first come first serve with NO HOLDING.
5spd LSD Rear
Clean title in hand
NO TRADES
