Hello All,
It is with a heavy heart that I need to post my Talon up for sale.
It's a 1996 Tsi AWD with the front end conversion to 2GB Eclipse. Rear end is still original 2GA Talon.
This was car built with the intention of road racing with GridLife, SCCA, NASA and others.
I have a full build history and chronology at the build thread here: https://www.dsmtuners.com/dsm-profiles/1996-eagle-talon-tsi-awd.16310/
Since this is a racecar, it comes with all of the requisite safety items - containment seat, 6-point harness, window net, fire system, electric cutoff switch. All is designed to meet SCCA/NASA/GL criteria and working properly.
Most of the issues that were left at the end of the build thread have been addressed in one shape or form throughout the past winter.
Below is a basic build list, but a more comprehensive one can be provided.
Some images are relatively old (such as after the cage was installed but interior not assembled). More up to date pictures will be added this weekend during a warm day.
Located in Detroit, MI.
Price is negotiable but within reason.
Engine Block | ||
Block | 6-Bolt (90-92.5MY) | |
Crank | Stock | |
Pistons | Nippon cast hypereutectic, +0.20" oversize | |
Rods | Stock | |
Main Bearings | ACL Race "Tri-Metal" | |
Rod Bearings | ACL Race "Tri-Metal" | |
Oil Pump | Stock | |
Cylinder Head | Head | 6-Bolt (90-92.5MY) |
Intake Valves | +1mm Oversize Stainless | |
Exhaust Valves | +1mm Oversize Stainless | |
Ports | Ported/Smoothed | |
Camshafts | Stock | |
Camshaft Gears | Stock | |
Valve Seals | Viton | |
Intake | Mainfold | Stock 6-Bolt |
Intercooler | VRSF 33" x 14" x 3.5" core | |
Piping | 2.5" diameter | |
BOV | HKS vent-to-atmosphere | |
Turbo | Turbo | MHI "Small"16G |
Manifold | Stock | |
Exhaust | 3.0" | |
Boost Control | Hallman Manual | |
Engine Control | ECU | Stock - DSMLink V3 tuned on Speed Density |
Wideband | Innovate | |
Misc. Gauge | AEM X-Series Oil Pressure | |
Misc. Gauge | Autometer Water Temp | |
Misc. Gauge | Autometer Boost | |
Transmission | Trans | 2G 5-Speed |
T-Case | Stock | |
Diff | 2G LSD | |
Clutch | ACT 6-Puck Spring | |
Pressure Plate | ACT 2600 HD | |
Flywheel | Stock | |
Brakes | Front Calipers | CTS-V |
Rear Calipers | 2G AWD Stock | |
Front Pads | PFC 331 (spares of EBC RP-1 and RPX) | |
Rear Pads | Porterfield R4E | |
Lines | Stainless Braided (no brand) | |
Front Rotors | 13" Ford Cobra | |
Rear Rotors | 2G AWD Stock | |
Cooling | Radiator | 2G Mishimoto |
Fans | 2G Mishimoto w/shroud | |
Oil cooler | Generic 24 row | |
Suspension | FR Coilovers | Redshift - tuned BC Racing |
FR Springs | 14kg | |
RR Coilovers | Redshift - tuned BC Racing | |
RR Springs | 11kg | |
Front Susp Arm | Adjustable +/-1.5deg | |
Rear Susp Arm | Volk Radius Rod | |
Volk Rear Lower Arm | ||
FR Sway bar | ST Technique | |
RR Sway Bar | RM racing | |
Exhaust | STM Tuned 3" catback with custom v-band blange | |
Interior | Seat | OMP HTE-R |
Harness | OMP 2" 6-point | |
Window Net | OMP | |
Steering Wheel | OMP 330mm diam | |
Fire System | LifeLine Zero 2020 | |
Exterior | Wing | 9 Lives Racing 70" span, custom uprights |
Splitter | 3" birch plywood with Professional Awesome mounts | |
Wheels | 949Racing 6UL, 17x9 +55 with 20mm spacers | |
