Please Support Kiggly Racing
Please Support Rix Racing
For sale 1996 eagle talon TSI AWD automatic
Sold
Near stock 98k miles
$7,000.00
Status
Status
1 member is watching this ad
Ad details
I’ll help ship anywhere . Most cities in the U.S cost $500-$1300 depending on how far you are from SLC UT. Looking for a quick sale , lowed to 7,000. I need the space for a evo coming home.
1996 Eagle Talon TSI AWD turbo auto near original . Wheels on the car are aftermarket but I do have the Oem rims for the car as well (painted black). Suspention has been changed to an adjustable when all the suspension work was performed. Switch was added for headlights on steering column. Need a harness pigtail to remove toggle switch and put back to Oem.
This Talon has 98,800 original miles 4 owner car. This Talon has been in AZ, UT and ID it's whole life. interior is near mint.
I bought it with the intention of pulling the dents on the rear quarters fixing the bumper and adding it to my DSM collection but things have changed. DSMs are climbing in value fast, especially the un modified low mile examples.
compression is solid on all 4 cylinders 140 ( can send video )
It doesn't burn oil. turbo pulls strong, car shifts like it should in all gears. Been in the garage for a while with no visible leaks.
no check engine lights . ABS light comes on and off now and then.
Talon drives straight. Does have a few common plastic interior vibrations while driving on the freeway.
Enkei wheels with brand new Kumo all season tires.
Brake rotors, calipers, and pads have all beenreplace all the way around with new OE parts.Brand new battery and alternator.Crank angle sensor was just replaced last year with new OE sensor.Timing assembly replaced at 90k, pullies and gates timing belt. front suspension has been replaced with new OE parts, control arms, ball joints, tie rods.
Sun roof works like it should, windows work like they should. Door handles are Oem and work like they should. Oem radio and speakers work great.
car is located in sandy UT . Clean title in hand.
Feel free to text me for any additional pics, videos or a FaceTime call with the car.
801-708-9799
  • Like
Reactions: 92Turbski
Latest questions
You should add that this is an Automatic car. That is desirable to some of our members :thumb:
Tanner Miller
Tanner Miller
For sure. Thanks for the tip. I figured they would look at the interior pics and see that it is, but putting it in the description is a good idea. Thank you
One member found this helpful.
