1993 Eagle Talon TSI AWD $9,500
- Clean Title in Hand ( in my name )
- 95,600 miles ( 3,600 on engine )
- NO RUST
- 5 spd Manual with LSD Rear Differential
- Located in 08080 NJ
Hey guys, I’m putting another DSM back into our community ( 6th car this year ). Overall the car is very clean with no rust and decent paint. It runs and drives well and does not need to be towed or trailered. I will list some of the parts and modifications on the car below.
- 6 Bolt Engine (3,600 miles on it )
- Ross 9.1 Pistons
- Eagle Rods
- ARP Main & Head Studs
- MLS Head Gasket
- ACL Bearings
- Balance Shaft Eliminated
- Comp 272 Cams
- Adjustable Cam Gears
- Supertech Valve Springs & Retainers
- Big Bore Lifters
- DSM Link V3
- Speed Density
- 4 Bar Map Sensor
- 16g Turbo
- 3” Turbo Intake
- Turbo XS Manual Boost Controller
- Megan Racing o2 Housing
- AEM Wide Band
- ETS FMIC Kit
- Walbro 255 Fuel Pump
- FIC 850cc Injectors
- Thermal R&D Exhaust
- NGK Plugs & Wires
- Poly Engine Mounts
- ACT Clutch
- Aluminum Radiator & Overflow Bottle
- Battery Relocated To The Trunk
- Rear Toe Eliminator Kit
- Rear Upper Adjustable Control Arms
- 17” Enkei Wheels (wheels could use paint)
- 225/45/17r Continental Extreme Tires
- NO RUST
- Ross 9.1 Pistons
- Eagle Rods
- MLS Head Gasket
- ACL Bearings
- Comp 272 Cams
- Big Bore Lifters
- DSM Link V3
- Speed Density
- 4 Bar Map Sensor
- 16g Turbo
- 3” Turbo Intake
- AEM Wide Band
- ETS FMIC Kit
- NGK Plugs & Wires
- ACT Clutch
