For sale 1g 1992 Eagle Talon TSI AWD part-out
Semi-built part out, time and money to other projects
$50.00 to $1,500.00
Status
5 members are watching this classified ad
1992 eagle talon tsi AWD 5 speed semi-built partout. Moving on from this particular toy, had it for almost 17 years, got a lot of other projects I'm wanting to do and hate to see it sit. Runs/drives etc, no issue other than ugly and no real interior left besides dash and front seats.
Body has 185k
Most of the cars major parts have 20k on them since I originally got the car, a lot of stuff has been added within the last 8-10k or less.
Engine:
Refreshed 6-bolt 2.0 w/ ~20k on it. Hyundai 1.8 head (more compression), stock turbo cams. ARP head studs, BSE. New oil pump, water pump and timing set w/ ~1k on it, Evo 9 belt and OEM tensioner. Stock I/M ported to accept S90 74mm TB. Stock exhaust manifold with ported collector. Cylinder 1-4 Cold compression test: 149, 148, 143, 151psi; Hot compression test: 151, 156, 150, 158psi. Legit S16G with billet-extended tip compressor, ported 8cm eBay turbine housing. Brand new black top CAS. Newer alternator. Poly motor mounts. FIC 1000CC low-Z injectors, fuelab AFPR (gauge is inop, have another IIRC), Aeromotive 340LPH stealth pump, rewired fuel pump circuit. Fluidyne race radiator, Samco silicone radiator and heater hoses. Milled HD AER valve cover with dual sealed catch can system, -10AN ports. Fluidampr balancer.
Transmission & drivetrain:
90HD trans, welded center diff. Stock resurfaced flywheel, FX carbon/kevlar clutch (cheap, but has worked for me, always considered it temporary). Skate bearing shifter bushings on trans side, Symborksi shifter base bushing and stock bushing rebuild with weighted DC shift knob. Newer master/slave cylinder with braided SS clutch line. Have new front axles as DS CV tore a boot recently. Stock t-case, rebuilt stock driveshaft. MT90 w/lightweight shockproof always in trans, heavyweight shockproof in t-case. LSD 4-bolt rear, MT90 & heavyweight shockproof in it always.
Brakes and suspension:
Outlander big-brake upgrade with slotted/drilled rotors, 3g brake master/booster combo. Braided SS brake lines on all 4 corners. Tein S-tech springs and KYB GR2 struts (~1k mi). Flyin' Miata de-powered steering rack, new inner/router tie rods, newer ball joints etc. aluminum strut bars front and rear. Trailing arms w/ Volk rear active toe eliminators. Fresh wheels bearings w/ 20k mi. front & rear. Engalls rear camber arms.
Power and electronics:
ECMLink V3, e-prom converted ECU, mild tune (275-300hp est.) Innovate dual-functions gauges (AFR/boost & shift light/oil pressure & temp). Innovate wide band sensor. GM 3" MAF, IAT & 4 BAR Omni MAP sensor, ECMLink maf adapter cable with ethanol sensor pigtail (have sensor, not installed). Also have a first gen, BNIB never used PiLink data logger, never got around to installing it.
Custom W2A intercooler system, 2.5 gal reservoir, -16AN lines, Jabsco pump, dual pass heat exchanger with dual 10" fans. Synapse synchronic BOV (recirculated).
A lot more im probably forgetting, check picture and ask, I have a lot of other DSM parts stock as well. Building price list daily, I'll update it as I can and when things sell. Not interested in selling the whole car particularly. Chassis/shell will be for sale once done, rebuilt title in my name.
All sales are: part cost + shipping and PP fees. Insurance is extra and responsibility of purchaser. Everything is sold as-is with no implied warranties or guarantees, and all sales are final unless otherwise agreed upon by the purchaser and myself. I'm happy to give as much information as possible. Ill entertain reasonable offers.
-Engine long block SOLD
-transmission/t-case/shifter cables & shifter SOLD
-Clutch/flywheel SOLD
-Aeromotive fuel pump SOLD
-Ecmlink v3/link cable SOLD
-Pilink SOLD
-BNIB front axles SOLD
-HKS clear cam gear cover SOLD
-6-bolt 3 piece timing cover SOLD
-MAF adapter cable w/ 3" GM MAF, GM IAT, GM Ethanol sensor and Omnipower 4 bar MAP SOLD
-Fluidyne radiator SOLD
Rubber hood bumpers SOLD
-Milled HD AER valve cover: $600
-Dual catch can setup: $60
-Stock I/M (TB opening port-matched) & S90 TB: $200
-s16g billet wheel turbo: $475
-Nearly new black top CAS: $150
-Complete W2A intercooler setup (I/C, pump, reservoir, heat exchanger, fans, lines {requires modification or different reservoir}): $650
-Synapse synchronic BOV/BPV: $175
-driveshaft w/ updated front yoke: $120
-4 bolt LSD rear diff & axles: $600
-flyin Miata de-powered steering rack w/low mileage inner/outer tie rods: $175
-rear trailing arms with Volk active toe eliminator: $225
-Ingalls rear camber arms: $120
-near new struts & Tein S-tech springs: $400
-outlander front big brake brake setup: $300
-rear brake calipers: $250
-SS Braided brake lines (all 4 corners): $100
-Fuelab AFPR (gauge inop): $75
-innovate MTX series gauges (boost/shift, WB AFR, oil press/temp) with all associated sensors: $320
-flaming river battery disconnect switch: $100
Message here or text 509610ninenine73.
Latest questions
Interested in the engine, tranny, clutch/flywheel, front axles and the maf and cable. How much to ship it to 67037?
Do you have a rear camber kit?
ThunderChild
ThunderChild
Yes, the car has engalls rear lower camber arms and Volk active toe eliminators. Forgot to list the engalls before.
ThunderChild
Watchers
5
Discussion
2
Location
Spokane Washington
