1992 Eagle Talon TSI AWD manual 6/4 combo
VIN: 4E3CT64U9NE127286
Mileage: 85,515
Price: 8,500
3 owners (technically only two)
Title and registration in hand
1992 Eagle Talon TSI AWD manual. 6/4 combo.
Tan leather interior.
PROs:
This talon is 100% bone stock front to back. Pinch welds are straight. Body is solid. Everything works as it should and is ready for its next owner. It is available to show and test drive and can put it on a lift if desired.
Recent work I’ve done:
-Ecu socket replacement by ecmtuning.
-Fresh gas tank and fuel fill neck assembly
-New fuel pump
-Restored fuel sending unit assembly
-New brake calipers, rotors and pads. Rear calipers rebuilt by Josh Bachman.
-STM stainless brake lines
-New hatch struts
-Fresh oil change with oem filter
-Transmission fluid flush with oem fluid
-Brake and clutch fluid has been flushed and bled.
CONs:
-Paint isn’t the best. After being garaged its whole life, it was then left outside the last 3 years to sit by the previous owner where sun and salty snow cause paint fade and cracking on the hood and hatch. (Was never driven in the snow)
-Needs a valve cover gasket
-Tires will need replacing (dry rot)
-Has a handful of broken bolts in the left rear wheel well from removing the splash shield to replace the fuel fill neck
-Drivers seat has wear
-headliner could use some attention
Mileage: 85,515
Price: 8,500
PROs:
-New fuel pump
-New hatch struts
CONs:
