1990 plymouth laser turbo
4g63 6 bolt motor
Recent timing belt, water pump, radiator, and thermostat
16g big housing turbo
Off road downpipe
External wastegate dump
Boost controller (17psi)
Aftermarket fuel pressure regulator
Walbro 450lph pump
SAFC2
Car is tuned on e85(pump) with safc2. Runs and drives well, but needs more fuel at wide open throttle peak rpm. Runs better on 91 in the winter
Ac and heat both work
Body is super straight and primered. Ready for paint of your choice or wrap
All that is needed is dsm link and completion of tune to be an easy 350whp car.
Comes with a box of parts for the car
Has a cooling issue that I don’t have the time to figure out. Selling for college money
Has a battery but is dead and will need a jump. Will overheat after enough time so needs to be trailered
4g63 6 bolt motor
Off road downpipe
Walbro 450lph pump
SAFC2
