- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- Evo 8 560cc Injectors, 2G MAF, 255 In-Tank Walbro Pump, Fuel lab AFPR w/ Lines from tank to rail and back, K+N Air Filter, NSX Boost Controller, Side mount intercooler with Punishment racing hard pipes, Prothane motor mount inserts, aluminum shifter bushings
- Mods-Engine
- Rebuilt 6 bolt, 8.3:1 Wiseco Forged Pistons 0.040over, ACL Main and rod bearings, MLS Head Gasket, Brian Crower Valve Springs and Valves, BSE, OFH Mod
- Mods-EMS & Logging
- ECMLink V3, MTX-L Wideband, Autometer Boost Gauge
- Mods-Drivetrain
- Rebuilt stock trans with double synchronized 1st and 2nd gears and welded center diff, ACT 2100 Clutch Kit, New OEM shift fork, pivot ball, and TOB, New Driveshaft Carrier Bearings and U-Joints
- Mods-Handling
- P205/55R16 Potenza RE970AS tires on stock 1g rims painted black with red lip (for better performance), Front and Rear strut tower bars, eliminated all a/c lines, condensor, and compressor and all power steering lines and pump, and EVAP Canister, Stock brakes and suspension
- Parts Wishlist
- Not a part but, NO OIL LEAKS!, coil-overs, rebuild rear subframe and 4 bolt rear end, reaplce all front bushings, rebuilt T-Case, 16g, full 3in turbo-back exhaust, FMIC
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
