1998 Mitsubishi Eclipse GST Vehicle Profile & Build Thread
Street Build
I bought this car from a craigslist ad saying it needed a block rebuilt. I got there and the kid told me that the block had already been replaced. I check it out and it was a new motor! Thus began the build...
Z28 Slayer
Ownership Status
Currently Own
Turbo Type
16g
Drivetrain
FWD
Automatic
Build Type
  1. Street
K&N filter
Injen Intake
Stainless Tubular o2 housing
NGR BOV
Rebuilt ported 2G head - new guides and seals
Megan Racing 3" downpipe
3" Exhaust - turbo back
Sickspeed catch can
Earl's Performance SS Brake lines
Power Stop cross drilled and slotted rotors
Halman MBC
Brian Crower 272 Exhaust cam
Walbro 255lph pump
Evo 8 560cc injectors
MHI Evo III Big 16G
Punishment Racing FMIC
HKS Turbo Timer Type 1
1G Black Top CAS
cruise control delete
AC delete
Balance shaft delete
EGR/Evap Delete
FP exhaust manifold
Evo III intake manifold w/ coil bracket
1G 60mm throttle
Fuelabs 818 Fuel filter
Fuelabs 515 fuel pressure regulator
Stainless Steel -6AN fuel lines
Custom built fuel pump bulkhead
ARP Headstuds
Mods-Engine
1992 6-Bolt Block,
Balance shaft elimination kit
Mods-EMS & Logging
AEM Boost -35hg - 35psi
AEM Oil pressure
AEM UEGO Wideband (upstream mounted)
ECULink V3
Evo 9 MR 1.5 bar boost gauge 1.5"
Evo 9 MR voltmeter 1.5"
Front and rear upper strut bars
Evo 8 Brembo front rotors and calipers
17" Konig Backbone on Yokohama S Drive tires 17x7.5 +38
Parts Wishlist
BC 268 intake cam
Kevlar timing belt
Background
300hp goal @ 20psi
  • Like
Reactions: Gst guy Jose
