- Year
- 1993
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- MHI td05h-20g built by FP,Hallman evolution pro MBC, 2g ported exhaust manifold, evo 3 02 housing, Megan Racing turbo back 3in exhaust, FP intake pipe, k&N air filter,VRSF fmic, hks ssqv bov, FIC 750cc, TRE performance 255 lph, afpr with gauge, prothane motor mount, big aluminium radiator
- Mods-Engine
- 6-Bolt, Mahle 9:1 pistons, Scat rods , dks 264/272, Manley valve springs, mitsubishi composite head gasket, arp head studs, balance shaft eliminator kit, acl tri-metal race main and rod bearings, NGK 7mm wires, ngk BR7ES plugs gapped at .028
- Mods-EMS & Logging
- Dsmlink v3 running SD, prosports egt, oil pressure and boost gauges, Innovate lc-1 wideband
- Mods-Drivetrain
- Fidanza aluminium flywheel, XTD stage 4 sprung clutch with oem TOB
- Mods-Handling
- Energy suspension front A arm and rear trailling arms bushings, ebc drilled and slotted front rotors, eagle alloys 17in wheels with 225-45r17 Goodyear Eagle GT HR tires
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
