xRichieRich07x's Eclipse N/T (w/turbo)
- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse N/T
- Transmission Type
- Manual
- Mods-Bolt-on
- 14b turbo, Hallman ES mbc set to 20 psi, Custom 3" turbo back exhaust with n1 muffler and 3 inch straight pipe, K&N Intake, 26x8x2.75 short route FMIC with 2.5" aluminum piping, 255lph Walbro fuel pump, 450cc blue top injectors, polyurethane motor mounts, aftermarket fuel pressure regulator.
- Mods-Engine
- rebuilt a 90 turbo 6 bolt and swapped with my n/t turbo 6 bolt. Block bored .020 over with 8.5:1 compression pistons, block was hot tanked, valves resurfaced, crank polished, new main and rod bearings, balance shafts removed
- Mods-EMS & Logging
- Autometer boost and air/fuel gauges, friend's datalogger.
- Mods-Drivetrain
- Swapped n/t tranny with stock turbo tranny, ACT 2100 with street disk
- Mods-Handling
- KBY GR-2 Gas struts/shocks, Eibach pro springs
- Parts Wishlist
- Garret ball bearing turbo setup 1g AWD, new wheels, new interior, Shep tranny, limited slip for my fwd would be nice, wideband o2, dsmlink. Basically everything better than what I have wouldn't hurt :)
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
