xojaycavox's Talon TSi AWD
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Mods-Bolt-on
- 255 lph Walbro Fuel Pump
Ported 2g Exhaust Manifold
Mitsu EVO III 16g turbo w/34mm flapper
Mitsu EVO III Ported O2 Housing
3inch Megan Downpipe w/Cat eliminator
3inch Thermal R and D Catback Exhaust
Fluidlyne Aluminum Radiator
Tial BOV
- Mods-Engine
- 4g64 crank, pressure cleaned, hot tanked, Resurfaced deck
Bored .020 over
JE 8.5:1 Pistons w/JE pistons rings
Eagle ESP Rods
Clevette77 main and rod Bearings
ARP Main, Rod, Head Studs.
Balance Shaft Elimination Kit
New OEM Water pump and Oil Pump
2g Extremely ported Stage III Head
1mm Oversized SS Valves
Crower Valve Springs and Retainers
Crower 272/272 Cams
2.5inch Mandrel Bent I/C Piping
32x12x3 FMIC
1g bored 65.5mm Throttle Body
1g Intake manifold
1000cc FIC Injectors
- Mods-EMS & Logging
- Greddy Profect B SpecII Electronic Boost Controller
DSM-Link v.2
- Mods-Drivetrain
- Built TRE Stage III Race Transmission
-All new Hub and Sliders
-All new Syncros, doubled 1-4
-New 1st/2nd and 3rd/4th steel shift rail w/ forged rail end
-All new seals and bearings
-Enlarged oil passages
-New snap rings, roll pins, end nuts, bearing shims, ect.
Fidanza Lightweight Flywheel
SBR4000 Clutch and 3500lb Pressure plate
Rear Vicious LSD
- Mods-Handling
- Full Megan Coilovers
-Fully adjustable heights
-Fully adjustable 32 level dampening
RM Front and Rear Sway bars
NeuSpeed Front Strut Brace
Brembo Cross Drilled and Slotted Rotors
Hawk HP+ brake pads
17inch 6-Spoke -Lenzo Rims
6-point Roll Cage
- Parts Wishlist
- fp race manifold, bigger turbo, dbb 50 trim or fp3052 :) anybody have one for sale?
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
