- Ownership Status:
- I own it
- Turbo Type:
- 20g
- Drivetrain:
- AWD
- Transmission Type:
- Automatic
- Build Type:
- Street
- Mods-Bolt-on:
- carbon hood & trunk lid, under glow, 3" turbo back & test pipe.20g turbo,46mm wg, alumunum rad, polyurathan motor mounts, 255lph fuel pump (rewired),1000cc injectors, 3.5 gm maf
- Mods-Engine:
- 272 cams, ported head, bs removed,9:1 manly pistons 20 over, eagle rods, all arp bolts,3g lifters, FP exhaust manifold
- Mods-EMS & Logging:
- dsmlink,oil temp, water temp bost & vac, wide band, turbo timer,dynatek ignition
- Mods-Drivetrain:
- air ride suspention, 3200 stall covertor, rebuilt itp tranny, drilled out valve body, high presure oil pump
- Mods-Handling:
- 18" rims 12.5" willwood braks
Join the Community!
Comments
Sort Comments By
